The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
How would you fix the left bumper?
The left bumper on my Series controller stopped clicking. The bumper now just squishes and does not record the button press.
Add a comment
Chosen Solution
I'd probably guess that replacing the bumpers would help. iFixit sells replacement bumpers here. There isn't a repair guide for this, but you can follow this disassembly guide up to the part where the bumper is removed, swap in the new bumper, and then follow the video in reverse to reassemble. If this doesn't work, your best bet is most likely just sending it to Microsoft for repair, or even just buying a new controller.
Replace your controller's bumper assembly compatible with Xbox Series X model RRT-00010 and RRT-00013 gaming consoles. Fix issues like a cosmetically damaged or bent bumper cover. Image
Product
Microsoft Xbox Controller (Model 1914) Bumper Assembly
$9.99
Score 3
Add a comment
Usually just try to replace it (it's actually cheap and available) but if you don't have a good soldering skill you will have nightmares with it
Add a comment
It’s is not pressing down correctly
Add a comment
Add your answer
David Evans will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 92
All Time: 14,525
