The Motorola Moto 360 3rd Gen is a smartwatch released by Motorola in 2020. It utilizes Wear OS and is identified by model number M360FS19-RG.
Battery replacement for Moto 360 3rd Gen
Does anyone know where I can get a replacement battery? I think that is my issue since I am stuck in a boot-loop with a battery charge icon when the power button is held down. The battery is 1ICP5/24/28 (APP00306).
Score 7
2 Comments
Wondering if you were able to find an answer to your problem?
by
Same problem, couldn't find this battery. If anyone has better luck pls post a link or some info.
by
Add a comment
Most Helpful Answer
Ebay is probably going to be your best bet for parts like that. Otherwise Amazon might have what you need. Otherwise I can't seem to find a specific sight for something like that.
Score 1
1 Comment:
As I could research on the web, the tech specs of the Original Battery are identical to this APP00286 battery.
Tension: 3.85V / Charge 4.4V
Capacity: 355mAh (1.36Wh) (aprox.)
Dimensions: 5×24×28 mm
I found it to buy at Aliexpress.
I bought one to try it out.
LINK:
https://pt.aliexpress.com/item/100500901...
by
Add a comment
I had this problem, but I contacted Motorola and they sent me a new watch. Can't find this battery anywhere.
Model APP00306 1ICP5/24/28 battery
1 Comment:
How were you able to contact Motorola?
I have the same problem, but haven't gotten through to any repair or replacement services. The sites and phone numbers I have found send me on a loop back to an automated email response or long dead phone numbers.
by
Add a comment
+3
Replacement batteries for the Moto 360 3rd Gen can be difficult to source directly, but you have a few viable paths to get your watch running again: [1]
  • Official Parts: Check Joe's GE Parts Store to see if the 355mAh battery is in stock, as they occasionally carry salvage OEM batteries.
  • The "Donor" Method: Since the exact APP00306 is rare, users in the Reddit Moto360 Community recommend buying an APP00286 battery (often found on AliExpress). It shares identical technical specs, but you will need to carefully desolder and solder the original ribbon cable to the new battery.
  • DIY Guides: You can use the iFixit Motorola Moto 360 3rd Gen Battery
Add a comment
Add your answer
Rhoan Walters will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 48
All Time: 2,016
