The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Altim 2006 2.5 - Poor Acceleration
My Altima 2006 2.5 runs perfectly on a flat road but is very lazy while going up a hill.
I have changed the pressure pump, changed all the coils but still the same issue.
Any help??
Secondly, its has a hard starting
Add a comment
1 Answer
Chosen Solution
@laminturay have the OBD scanned. It appears that your Altima has difficulty whenever under a load (where it has to work a bit harder) This could be a fuel problem as well as a combustion issue (poor compression etc.) as well as issues with the emission control. There are to many possibilities and we'll need a good starting point.
There are a few things that can be commonly causing this. You would need to check for a clogged air filter, worn spark plugs, dirty mass air flow sensor (MAF), dirty throttle body, clogged fuel filter, bad fuel pump, failed oxygen sensor, and even a clogged catalytic converter. Anything after that would be deeper inside your engine like blown head gasket, bad piston rings, leaking valves etc. As you can see the list can be pretty extensive.
Score 1
1 Comment:
Thank you so much. I will start with the OBD first to see what exactly the issues are.
by
Add a comment
Add your answer
Bilal Mohamed Lamin Turay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 672
