Released October 2, 2001, identified by model number DVP-FX810
Line in won’t work
Line in won’t work with my thing
(Wii av port)
2 Comments:
Logan Lamothe your "thing" being a DVP-FX810? Sounds like you are trying to connect a WII to it. Is that correct? What happens when you try?
by
No picture appears and it still says line in
by
Add a comment
1 Answer
Logan Lamothe follow the instructions in your manual. If you do not have one, you can download it at places like this
You need to check/set the side switch LINE SELECT IN OUT and see if that changes anything. Of course you also have to make sure that your AUX cable is compatible. Double check the manual for all of this.
Add a comment
Add your answer
Logan Lamothe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 314
