The Lenovo Chromebook C340 is a laptop that can be used to type but can also be converted into a touchscreen device. This page contains repair information and service related to this device.
How to Change out charging port
My son damaged his charger and then jammed it into the charging port damaging it. Now I need to replace it and feel comfortable doing so based instructions online for similar devices but I want to make sure to order the correct replacement part. Can anyone help? The device is a Lenovo Chromebook C340-11
Add a comment
1 Answer
Most Helpful Answer
Hi
Here’s the hardware maintenance manual for the laptop.
Go to p.31 to view the necessary pre-requisite steps and then the procedure to remove/replace the I/O board (supplier example only).
Search online for 5C50S24976 to get results for suppliers that suit you best.
Includes USB ports and a cable to connect external devices to your laptop. Image
Product
5C50S24976 - Lenovo USB Board B With Cable
$8.99
Score 3
1 Comment:
This was so helpful, thank you so much!! I was able to remove the I/O board and I got a replacement ordered and on the way!
by
Add a comment
Add your answer
Brooke Gullett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 500
