Up to 20% off select tools
Released in June 2016, the Altec Lancing BoomJacket 2 is a small, portable bluetooth speaker. It is designed to work anywhere without the worry of it getting damaged by the elements. Model Number IMW579-AB-BB ( aqua blue)
Why does my speaker stop responding
I have the Altec Bluetooth IME579-AB speaker. Why does it stop responding when the Bluetooth setting on my phone shows it still has a 50% charge. Other Bluetooth devices are able to connect to the same phone and continue to work fine.
Add a comment
1 Answer
Try connecting it t charger and useing it. If it works that way and doesn't disconnect then you have a battery indicator that's out of sync.
Add a comment
Add your answer
David Elliott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 326
