My phone shutting down itself
Hello, I have a with my poco that he is shutting down itself, also he disconnects from wifi and won’t connect until he shut down. And when this happened he won’t register my sim card.
Hi,
To prove whether it is a software problem or a hardware problem you may have to perform a hard reset
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the phone to its factory default condition.
Backup the phone to the cloud or a computer before performing the reset. Also if there is a Google account tied to the phone, you will need to know the account name and password to access the phone once the reset has been performed due to the FRP lock (factory reset protection) being enabled by the reset.
If you’ve already done a hard reset (you didn’t mention if you did) then it is a hardware problem. So dropping the phone may have contributed to the problem. Here’s the ifixit Pocophone F1 guide that will help you to open the phone and check for any obvious problems e.g. loose connections or cracks in the systemboard etc.
I gave the cell phone a hard reset after battery change, but I think it has something to do with this chip https://forum.xda-developers.com/t/pocop...
@Peter Matava
If you're willing to take the chance you could reflow the chip and check but I don't know what temp you would need or for how long.
You would need to dis-assemble the phone and remove the systemboard to prevent damage to other parts of the phone when doing this.
You could always try contacting the person who fixed it and ask them. Here's their email address from the link you posted in your comment - servis@mikroteh.hr
I faced the issue of my Xiaomi phone shutting down unexpectedly and not turning back on. After spending quite some time researching the problem, I was able to resolve it at home using a few simple methods.
One of the steps that worked for me was performing a force restart, which can help in cases where the phone becomes unresponsive. I came across a helpful explanation on how to do this on a Persian-language support site that focuses on Xiaomi devices. It provided clear instructions that guided me through the process.
If you're experiencing the same problem, I suggest trying the force restart method first, as it might save you a trip to the service center.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 48
All Time: 3,104
5 Comments
Hi,
Does it shutdown with the charger connected?
Has the phone been dropped or gotten wet at all?
by jayeff
No its random .Yes phone been droped but no wet.
by Peter Matava
@Peter Matava
If it doesn't shut down when the charger is connected it may be a problem with the battery
by jayeff
Battery been replaced
by Peter Matava
Hi, i'm having the exact same problem. So this might be software
by Nicolae Ciobanu
