The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
wifi connect but next stop
Add a comment
1 Answer
Hoi Nandan Raj,
A late response here, but your issue could have used some more information.
Unfortunately, BlackBerry has since ended support for all mobile devices and has shutdown all servers related to those devices, including the BlackBerry Classic.
If your issue, was trying to set-up your BlackBerry Classic and are not able to pass the Wi-Fi screen, this is due to the server shutdown and your device will not be able to properly set-up due to that.
BlackBerry: End-of-Life Announcement
Not the news to hear about a device you use, but hopefully this helps with your issue.
Add a comment
Add your answer
Nandan Raj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 319
