Device repair and information for the Dell Alienware 15 R3, a gaming laptop in the Alienware series.
Spacebar cracked, how do I replace?
Was trying to remove the spacebar to clean and it cracked. Where do I get a new one and how do I replace it properly?
4 Comments
Is this an internal laptop keyboard or a separate desktop keyboard?
by
William Waite your computer is a Dell Alienware 15 R3?
by
Duh, I see it now. Have you reached out to Dell to see how much a replacement keyboard is? That helps in computing a repair. It should also get you to install instructions to help you removing the keyboard to look at whether and how you can repair it.
by
Internal keyboard. Yes, Alienware m15 r3 I believe. I have not contacted Dell. Taking it to a repair shop tomorrow for analysis and estimate.
by
Add a comment
1 Answer
Most Helpful Answer
Hi ,
You may be able to fix it yourself.
Here’s a link that will help with this. Select your key and key type
Score 2
Add a comment
Add your answer
William Waite will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 19
All Time: 562
