Drum set accessory to the Wii game, The Beatles Rock Band, which was released in 2009 by Harmonix. This repair guide will give you help on fixing and/or replacing certain parts of the drum set. Identified by model number NWDMS3.
Will not power on
Recently got out of storage. There was some corrosion on the battery contacts, when cleaned off all connections were checked and there appears to be no damage inside the wire casing. Tried several different batteries. Looking for suggestions, or if it is a lost cause.
Add a comment
1 Answer
Most Helpful Answer
You could put a multimeter in DC voltage mode and check to see if battery voltage was making it to the actual circuit board.
Score 1
Add a comment
Add your answer
Jared P Neslen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 31
All Time: 481
