Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Why does my device not lift off
All the blades spin but it will not lift off the ground
Add a comment
Most Helpful Answer
Hi,
Have you checked that the propellers are fitted correctly and are in their correct quadrants?
Each blade has a number written on it. Match the blades with the corresponding number on the drone. If incorrect carefully unscrew the propeller and reposition it in the correct place.
Score 1
Add a comment
It could also be a expanding/defective battery. I’ve had a similar problem where the drone’s battery was expanding and could not supply enough power to lift off. I would find the voltage of that battery under normal circumstances and test the battery’s output. Hope this helps!
Add a comment
Add your answer
Paul Eyrich will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 55
All Time: 1,977
