A wireless speaker released in 2012
Bowers Wilkins A7 connection issue
I have a Bowers Wilkins A7 wireless speaker.
It can’t be connected successfully now either with WIFI, wire, USB or AUX. The red light just keep flashing indicating the connection issue.
Resetting the device didn’t work either.
It is an old device with little information on how to fix this.
Is there any way to check the root cause of the issue?
Score 1
8 Comments
Hi,
Have you tried resetting the device, you didn't say?
by
Yes, tried that.
After resetting, the red light just flashed.
by
Seems can't do the firmware update.
Connected with USB not work.
by
@Shawn Chen
Did you try using the Control app?
by
@jayeff
Yes, tried to but can't connect either.
The device can't connect in any way.
I have tried to reset and connect several times with no success.
by
Show 3 more comments
Add a comment
Most Helpful Answer
@Shawn Chen
The only thing I suggest now is to open the speaker and check for any obvious problems on the systemboard.
Here's a link that may be of some help. There is also a wiring diagram in the answer as well. ;-)
Bowers and Wilkins A7 dissassembly guide?
Score 2
1 Comment:
Thanks a lot @jayeff .
Will follow this and check accordingly.
by
Add a comment
@shawnchen
I think I have the same issue. And in my case I am sure it is the WiFi module, because I was able to swap it with a working WiFi module and then the A7 worked perfect.
So I am looking for a way to repair the WiFi module.
Here's my post.
Did you find a solution in the meantime?
Add a comment
Add your answer
Shawn Chen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 41
All Time: 1,907
