The Respironics BiPaP Vision is a respiratory ventilator (breathing assistance device) created by Respironics / Philips. Included is a mobile stand, various ventilator pieces that connect to the main device system, and a remote alarm. (Model Number: 582059)
Can it be used for CPAP
Can it be used for CPAP.
Add a comment
Most Helpful Answer
Tomasz Kosierkiewicz  no you cannot. The pressures delivered through BiPAP are different since it requires two separate pressures(IPAP and EPAP), whereas a CPAP does not have those and you cannot turn that off. If you feel your BiPAP is not working for you talk to your HCP for a different approach. Also, check your Respironics model number and make sure it is NOT involved in the recent recall. Check on here https://philipsrecalls.com/ Do not use it until you are sure that it is safe. Again, contact your HCP for assistance with this.
Score 1
Add a comment
we legally can not give advice for medical equipment
Add a comment
Add your answer
Tomasz Kosierkiewicz will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 433
