Miposaur is a robotic dinosaur made by WowWee in 2015 and its model number is OKP0890. This guide will provide resources for and information on repairing a broken Miposaur.
Battery holder is corroded
Battery holder is corroded can I get replacement
1 Comment:
Can you not clean it of corrosion? A small metal brush should be able to clean all the corrosion from the batteries out, and then it should be fine.
I haven't been able to find anyone that has the battery cartridges in stock. You could always change it to a rechargeable battery pack. Wowwee's website has those in-stock.
by
Add a comment
1 Answer
mix some baking soda with water and using a q-tip dab it and rub off the corrosion. when you get it clean than apply some dielectric grease and it shouldn’t corrode again at least not for a very long time.
Add a comment
Add your answer
June Page will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 259
