How to hard reset jbl tuner 2
My jbl tuner hang. I can't power down or up. Pressing button doesn't work.
Score 4
4 Comments
Masalah saya cara ngilangin MCU UPDATE di jbl saya gimana mas,soalnya kalo ada tulisan itu speker saya ga berfungsi,makasih
by
Dear team,
i have the same issue, jbl tuner 2 won't turn on, where i can find the file to upload?
by
Mijn display is niet leesbaar , licht op maar niks te lezen
by
mijn display is niet meer leesbaar
by
Add a comment
Chosen Solution
Ok you need a pc and usb cable to connect your pc to your jbl tuner.
  1. Connect your jbl tuner to your pc.
  2. Press and hold [DAB/FM] and [Volume -] buttons simultaneously for >10 seconds, until you see message on display “connect to PC then copy updated File”
  3. At your PC find your USB Drive and press eject.
  4. Your jbl tuner 2 will reset and turn on again in 10 seconds.
Score 11
6 Comments:
I tried this procedure on my acer chromebook. All went well until I clicked in the wrong place. Now my jbl tuner dab/fm is frozen," No update file" is on the display. Now it won't power off .
by
Thank you! That's was Ok!
by
Perfect solution!
by
Yes worked for me
by
oh great, that worked. I thought I had blown up the JBL Tuner 2 by connecting it to a fast charger, after which I only saw the power indicator but it would not turn on anymore. But this solved it. I used a Mac instead of PC, so that makes no difference. Thanks!!
by
Show 1 more comment
Add a comment
I followed next link: https://files.zutphen.nu/JBL-Tuner-Hacks...
and had succes with pressing DAB-FM & BT at same time for force power off
Score 1
2 Comments:
Thanks Isoete,
No way to switch it on. Just pressing both DAB-FM and BT buttons actually solved the problem.
by
Thanks, DAB FM And BT buttons resolved issue for me too.
by
Add a comment
doesn't work. EXIT DFU MODE and than this "normal" text : Connect with PC or MAC than copy update File
Add a comment
Thanks for your help! I had the same problem. Just connecting it to my laptop and then ejecting the usb drive did the trick. Thank you so much!
Add a comment
Witam mam problem z jbl tuner2 nie mogę przywrócić ustawienia fabrycznych przy pierwszym uruchomieniu przez pomyłkę ustawiłem język wydaje mi się że to Holenderski i nie mogę go zmienić.
Add a comment
I don't have a DAB FM button. What is this?
1 Comment:
Sylvana check this picture for reference: https://manuals.plus/wp-content/uploads/....
If you only see an FM button though, then you actually have a JBL Tuner (v1), which doesn't support DAB (Digital Audio Broadcasting). The reset procedure is a little different, once the device is switched on, you have to press Volume Up and Bluetooth button combination and hold it for 10-20 seconds, as described here: https://www.hardreset.info/devices/jbl/j...
by
Add a comment
Great help, it worked.
though it was challenge to navigate my 77 years old mother over facetime to do this technical stuff on PC. Wrong usb cable, then she pulled out mouse cable by mistake and so on :-)
Anyway thanks.
Add a comment
If I connect the box to my PC, I don't see any message or USB file popping up in Files. What do I do?
Add a comment
My JBL tuner 2 only turns on when a charging cable is connected to it. It goes off immediately the cable is detached. Pls how do I fix it
1 Comment:
plug in and press preset 2 and preset 4 at the same time for 10 second to exit demo mode or just battery is dead
by
Add a comment
Hi there! My tuner 2 behaves very strangely. i can only turn it on when i disconnect the power cable (usb) after that it only plays music from the last radio station, no buttons work: i can't turn it off, i can't change volume, scan or change preset or input type.. it's like no button works, except when i press dab/fm + BT button it immediately shuts down (i don't even have to hold it down) and also the dab/fm + (-) workt to get to update mode.. so the physical buttons actually work.. but either updating it with the latest known firmware file or even just entering PC mode but skipping update file and ejecting will just cause a reboot but still with no response n button press after that.. the factory reset trick with preset 1 + BT does not do anything. Just combinations dab/fm + BT and dab/fm + (-) work .. any ideas?
Add a comment
Add your answer
Mohammad Fairus Khalid will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 223
All Time: 32,342
