The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
ASUS X555QG Screw Sizes
Is there any X555QG documentation on where the screws should be placed? I lost track and now I'm scared of breaking something inside.
I have
4x 9mm
and 6x 11mm.
Add a comment
1 Answer
Chosen Solution
Hi @banesrb ,
I couldn’t find any information regarding the locations of the screws in the laptop but here’s a list of all the screws that are used.
There are no 11mm screws in the parts list so presumably they are the M2*12L (12mm) screws.
Perhaps you could use a thin wire and insert it into the screw holes and then mark the wire so that you can measure the depth of the hole. A difference of 3mm between the screw lengths should be easy to discern
Score 2
1 Comment:
I guess this will be close enough, thank you.
by
Add a comment
Add your answer
Bane will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 21
All Time: 1,254
