The Nokia 7.1 Android smartphone was released by HMD Global, a Finnish mobile phone company, under the Nokia brand. The 7.1 was released in October 2018 and is an upgraded version of the Nokia 7.
How do I install software update directly
my nokia 5.1 phone has an issue in that whenever the battery is zero % it can’t power on again not until you install the software again
Score 2
Add a comment
1 Answer
Most Helpful Answer
The problem is not the software, it’s the battery.
You can try to calibrate the battery by doing the following procedure :
  • Fully charge the phone and let it charge 1 more hour
  • Discharge the phone fully until it shut down
  • Fully charge the phone again
If calibration works, you should get a more accurate battery level.
If calibrate the battery did not resolve the problem, your phone’s battery is failing and should be replaced.
In order to restore your phone’s battery life and get a more accurate battery level, you should try to replace the battery.
Score 1
Add a comment
Add your answer
Fred Kamau will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 691
