My Nextbook table will not turn on?
My nextbook will only turn on momentarily when I plug in the charger. Why will it not turn with power switch? Is the batery bad? How do you tell?
Add a comment
1 Answer
If the battery is removable, try taking it out for about 10 minutes and put it back in. If that doesn't work, try a different charging cable.
If both fixes don't work, then the battery may need replacing.
1 Comment:
I disconnected the battery for about 5 min. with results. I will try a new chord when i get one.
Thanks.
by
Add a comment
Add your answer
Clifford Green will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 316
