Up to 20% off select tools
Repair guides, disassembly, and troubleshooting information for the 8th-generation Apple iPad, available in Wi-Fi and cellular versions with 32 or 128 GB of storage. Released in September 2020. Identified by model numbers A2270, A2428, A2429, and A2430.
Ipad home button flex
Hey i ripped the homebutton on My ipad. And have now Bought an new one. but It is completely straight how do I bend it so it fits in the ipad
4 Comments
Could you provide a picture of what you mean by completely straight. Does it not have the right angle bend to where it connects to the board?
by Share
http://imgur.com/a/pAhU6k here is a pic og the new and the old
by Share
It is add now the pic No it does not have the right Angel to connect to the board
by Share
The iPad 7 and iPad 8 use the same home button part, so I'd recommend looking at the iPad 7 home button replacement guide here on iFixit as it shows the way the flex is bent.
by Share
Add a comment
Most Helpful Answer
@joakim.lundgreen,madsen, where did you get this part from? I would check with the seller to make sure that this is the correct part.
Score 1
Add a comment
The only time for the past month when Surface Pen is actually put to use.
Ref: https://guide-images.cdn.ifixit.com/igi/...
Add a comment
Add your answer
joakim.lundgreen.madsen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 585
