Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
Why does my device overheat so often?
Good afternoon, I have a big problem. I have Asus Eee PC 1005HA. And it started to overheat very often. I often have to work at the computer and write a lot of articles, but lately my device began to overheat and shut down very often.
How can I solve this problem? Should I upgrade to a more powerful device, or is there anything else I can do about it?
Add a comment
1 Answer
Have you had the laptop for a long time? If so, if you have never taken it apart the entire time you have had it then it might be dirty inside and probably needs new thermal compound on the CPU. That is most likely the problem.
Add a comment
Add your answer
brian johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 28
All Time: 368
