Up to 20% off select tools
The Samsung Galaxy A71 is an Android smartphone manufactured by Samsung Electronics as part of the Galaxy A series. It was released in January 2020. Versions: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Russia).
Screen Issue Yellowish Pale Bright
My Samsung Galaxy A71 (Not 5G one) have a screen issue, The screen flickering and then become Yellowish and Brigther, Everything that usually black it become brown (such as Youtube Blank Space that doesn't fit / AOD / Samsung Logo when restart) First it's change from normal to yellow and then it's become permanent yellow full screen, flickering to normal sometimes or brighter and darker version. Everything looks pale and bright some sort of contrast maybe? I've try safe mode but it's still the same. I'm asking first because I don’t want to factory reset.
Add a comment
It sounds like you have either a bad display or an improperly connected display flex. Have you had the phone repaired recently?
2 Comments:
No I haven't repair my phone before.
by Share
In that case, you could take it to a repair shop so they can take a better look at it, or you could try replacing the display. However, with Samsung's phones, you have to go through the back to replace the front, and sometimes the back cover can break if you aren't careful.
by Share
Add a comment
Is there a fix for this issue? I have this issue rn. Usually screen turns black whenever i go through something black or when screen is hot
Add a comment
Add your answer
Gunsøu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,311
