The Toyota MR2 is a two-seat, mid-engined, rear-wheel-drive sports car manufactured in Japan and marketed globally by Toyota from 1984 to 2007 over three generations: W10 (1984–1989), W20 (1990–1999) and W30 (2000–2007).
How do I replace the shifter boot
The “boot” or housing that goes around shifter in my 87 MR2 has rotted away. I can see how to remove old one and slip new on, but not have to make it secure in opening again. think maybe I lost the aparatus that secures it sometime in last 30+ years.
Add a comment
1 Answer
Most Helpful Answer
Hi,
I’m not quite sure but is seems as though the boot (supplier example only) is held in place by the console upper panel and the gear shift knob i.e. remove the gear shift knob, remove the upper panel, slip the boot over the gear shift and into the console box, replace the upper panel and then replace the gear shift knob.
Here’s an image from the 1991 MR2 service manual where it shows the assembly of the console box. Hopefully it is the same for your year model.
If the console upper panel is broken, missing etc (not sure if you meant this) it is also known as the shift boot trim bezel but I can’t find any for your year model, only from 1990↑
(click on image to enlarge)
Score 1
Add a comment
Add your answer
Katherine Healey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 35
All Time: 589
