Up to 20% off select tools
The Sony Ericsson Xperia X10 Mini E10i runs on a custom version of Android and features 3G access. Released in 2010.
Water Damage
My Sony Ericsson xperia x10 fell into water and just went black. It still charges but now i need to see if it works.Should i send it to Sony Ericsson or how can i get it fixed?
Anna.Zimbabwe
Score 2
2 Comments
Anna is it an X10 or a x10 Mini E10?
by Share
toilet no good. dirty phone. buy new telephone.
by Share
Add a comment
Chosen Solution
Anna I would suggest that you first clean your device. Use this as your guide. After that, re-evaluate your phone. you can try a restore by downloading PC SUIT from here
install it, start the Software
Press Tools
Press Phone repair
Press Continue
Wait for PC Suit to download the file
Follow the prompts and select Model X10
Connect your phone while holding the back button and plug the USB cord in. Let the drivers install wan wait while it completes.
Again this may or may not work. I am really more leaning toward you needing a new LCD due to the water damage. But follow the steps anyway. You can download the compete service manual from here. Hope this helps and gets you started in the right direction. Good Luck
Score 1
2 Comments:
Sorry, I posted at the same time
by Share
Wow great minds think alike ;-)
by Share
Add a comment
Hey dear, the same thing happened to my experia arc. Gosh its brande new.. it fell into the toilet lol.
ok well, bo panic. all you should do is dry it with a vacuum. Or place in the sunshine for few hrs without touching it or turning it on constently please. turning on a cell when its still dry frys the cell. You can also place it infront of the fan for few hrs. When you see its completely dry only than put in the battery and sim and turn it on. Remember they drying process should be done with having the battery and sim out of it in first.
It will really help. If not, than you have to seperate all the partd and dry eah part individually. and fix it and turn it on..
Add a comment
pc suit
1 Comment:
What does that mean? Is it an answer or a question?
by Share
Add a comment
Add your answer
Anna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 5,394
