The Oster Expressbake CKSTBRTW20 is an electric breadmaker that was released in 2009, which has capabilities to make 2 lbs. of bread in under an hour using its Expressbake feature.
Device has stopped mixing.
Hello! I recently picked this up at a thrift shop since I have always wanted to try one. I’ve used it 7 or 8 times and the last couple times the paddle would stop spinning to mix the ingredients. I thought it was due to gunk on the paddle or the inner container wasn’t inserted properly. This last time it mixed maybe two times and then would have an audible “click” sound instead of turning the paddle. Does anyone know how to fix the motor or attachment?
Score 1
Add a comment
1 Answer
Andra Hutton could be the motor as well as the electronics. Let’s see what it looks like I suggest you start by disassembling it using something like this guide Oster Expressbake CKSTBRTW20 Inner Chamber Replacement
Make sure that mechanically it all looks okay. You can always post some of your devices images, with your QUESTION, while you do the work. that way we can see what you see and possibly assist you further. Let us know if you find some oddities etc. Adding images to an existing question
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Oster Expressbake CKSTBRTW20 Inner Chamber Image
Guide
Difficulty:
Moderate
20 minutes
Add a comment
Add your answer
Andra Hutton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 28
All Time: 487
