An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
left and right bumpers/triggers
the left and right bumpers/triggers do not work, no how much i press them
Score 2
Add a comment
1 Answer
Chosen Solution
Mitchell, the first thing I would try to do, clean the triggers. After a few years, there might be a lot of grime and debris that accumulates on/in the trigger. You should get some isopropyl alcohol and a q-tips. Wet the q tip and clean the edges of the trigger well. Should this not work and you feel up to it, dismantle the GBA. A good video to direct you is here Check on the trigger springs and button, make sure they are all in working order. You can purchase inexpensive replacements here and the buttons right here, Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Mitchell will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 82
All Time: 21,493
