Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
Dies too quickly! Why?
So why does my iphone 12 mini battery die quick after 5 months?
Score 2
Add a comment
Chosen Solution
İ kept it like that for a bit,and it actually (somehow),and it did stop doing that,idk how it fixed itself though,it did get normal even though it was before i was in 16.1.1,but after 16.1,so it wasnt an update
Add a comment
Most Helpful Answer
Check your battery health. (Settings>Battery>Battery Health.) From there check Battery health, Apple considers 80%+ to be optimal. if it is lower than 80%, consider having your battery replaced/replacing it yourself.
Score 1
Add a comment
well it says 99% battery health
2 Comments:
Sorry for the slow response.
If your battery is at %99 and already having issues I can only think of two possible issues. 1. a bug in whatever IOS version you are running is draining the battery. 2. There are app(s) running in the background causing your battery to drain.
Ways to fix:
For an IOS version causing battery drain, Down grade/Upgrade your IOS version.
For App(s) running in the background, close/uninstall unnecessary apps. (Each app's battery usage is viewable in your battery settings.)
Another thing to try would be a force restart.
Even though the guild is for a iPhone 11, it will work the same as a 12 mini.
(How to Force Restart an iPhone 11)
I would also try calibrating the battery (To calibrate your battery. First, charge it to 100%, then use the device normally like you would until it drains to 0%, then repeat the process 2 times. Your battery should now be calibrated.)
If all four of these things are unable to get your battery to function properly, I'd suggest replacing it.
Hope this is of some help! :)
by
I have an apple iPhone 8, it says 99%, it’s been more than 2 years since I got it. also something is that I don’t have a phone plan, wondering if that makes a difference
by
Add a comment
Add your answer
KAAN CAN will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 22
All Time: 2,850
