Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Logic Board Rubber Bumper Location?
I replaced the display assembly this weekend, but when I was attempting to reinstall the logic board (step 21 of the guide, in reverse), a small rubber bumper came loose from 'somewhere' on the board (I think).
Here's a picture of the bumper (with the broken screen as a backdrop to give you a sense of proportion). Can somebody identify where it belongs? It's seldom good when you've got parts left over!
Score 3
Add a comment
Chosen Solution
It goes on top of the Logic Board, under the two Front Screen Flex Cables. I have seen a couple of iPhone 4 without this installed or just missing and they functioned perfectly.
Score 8
2 Comments:
That did it!
by
That was a huge help. Thanks!
by
Add a comment
Also, notice there is a thick and thin side to the bumper, and the thin side should be on top, or toward the back panel.
Score 2
Add a comment
That little plastic bumper folds over the top of the logic board assembly where the Digitizer ( Front Panel) cables come up and over. If you look close at the bumper there is a small grove that is the same size as the boards thickness. Its just there to protect the Digitizer's cables from the rough surface of the logic board.
Score 2
1 Comment:
Thanks for that info... Super helpful
by
Add a comment
what would happen if you were to put this on the wrong way
Add a comment
Add your answer
Matt Strange will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 21
All Time: 7,831
