The Vizio e480i television is a 48-inch television produced by Vizio, Inc., which was founded in 2002 in California. The Vizio e480i is classified as a smart TV and can be identified by model number E480i-B2.
White light blinking then fading
Why is the white light blinking then fading to off and the television does not come on when I press the power button?
Add a comment
1 Answer
Most Helpful Answer
@orchid28 that is because your TV does not pass its own POST (Power On Self Test). It appears that one of your boards is not providing the feedback needed. Vizio is a bit of a different brand and uses a hodgepodge of parts. You will have to remove the back cover from your TV and check the boards for obvious damage. Make sure that all the ribbon cables are properly attached since Vizio has issues with bad connectors. Your issue is most likely power board-related and you would have to measure the connection t the main board to ensure it provides proper voltages. Post some good pictures of your boards so we can see what you see and we can try and provide more guidance to achieve a good outcome. Adding images to an existing question
Score 1
Add a comment
Add your answer
Jenna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 4,641
