The Razer Blade Stealth is a gaming laptop with a 13.3 inch wide screen. The laptop features 16 GB of RAM and an Intel Core i7 CPU. It comes in Space Grey and Mercury White.
New battery only works while plugged in
I just replaced my battery in my razer blade stealth and it works fine while plugged in but says charging and stuck at 97% and when I unplug it it turns off immediately and won't turn on while unplugged. The battery is brand new. The old one was fairly bloated.
Score 3
3 Comments
does the laptop power on without a battery?
by
@logixal yea it will power on without the battery connected
by
Exact same problem!
by
Add a comment
1 Answer
Most Helpful Answer
@riveteer I am certain you double-checked your work and made sure that your connectors are all properly seated and that there are no issues like bend pins etc. with those. I would contact the seller and replace the battery once more just to rule it out as the culprit.
Score 1
1 Comment:
Yea thanks. I did look around more today and was looking at the connector for the original battery and the one I bought from ifixit had a poor connector. I bought another and plan on returning the one I got. Thanks
by
Add a comment
Add your answer
Jack Kuckhahn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,116
