Up to 20% off select tools
Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
iPhone 12 battery replacement
hi, if i replace my iphone 12 battery with ifixit battery, does the battery health show up or not?
Score 1
Add a comment
Chosen Solution
No, if you replace the battery in an iPhone 12, battery health will stop working.
Score 2
2 Comments:
Does that mean that the % power remaining will not display in the upper right corner of the home screen on my iPhone 12, if I swap out the battery?
by Share
@lenayres1a93233 No, that's the battery's charge percentage, which is completely separate from the health percentage. You'll still be able to see the remaining power in the corner of your screen after replacing the battery.
by Share
Add a comment
i do not know 100% but knowing how APPLE is with their proprietary parts its kind of a gamble to expect that. ESPECIALLY Considering even OEM parts from THEM! dont work how theyre supposed to. IE the truetone feature when replacing with an OEM screen.
i hope this helps
Add a comment
It will not show but you can just Use 3utools to check your health with a computer. Why in the heck would you change the battery such a new phone
Add a comment
Battery health will not show, and you'll get a message showing that it can't confirm you have a genuine battery.
However, some places, (not many) will be able to spot weld the flex from your original battery to the replacement. Then reset the charge count.
Being so new, if there are problems with the battery, Apple should replace under a warranty seems most of the 12 range will still be under warranty.
1 Comment:
I have done it on XR, you can do it at home with spot welder. just buy battery cell for your iphone (without the flex and with more metal space to weld on). there are many tutorials on internet. after spot welding you have to reset the cycle count by icopy device.
My brand of the spot welder and icopy device is QianLi - you can buy it on aliexpress as well as me, its a little bit cheaper
by Share
Add a comment
Add your answer
Chris Rayn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,718
