Up to 20% off select tools
Repair and disassembly information for Sony WH-1000XM2 wireless noise-cancelling over-ear headphones.
Left speaker not working
Hi,
My left speaker stopped working. Touch is still working on the left side, right speaker works fine.
Can anyone advise which cables I should check/replace and Mark them in the attached image?
I have opened up the headphones.
3 Comments
Does the left speaker not work on wired mode(3.5mm cable), wireless mode(Bluetooth), or both?
by Share
It doesn't work wired and unwired
by Share
Hello,
Had the same issue with left speaker no longer working (after crackling for a few weeks),
The continuity of the wires was OK, however there is no continuity in the speaker itself once disconnected from the electronic board.
Do you know where to find a replacement speaker for hw-1000m2 ?
by Share
Add a comment
Most Helpful Answer
This sounds like a connection problem or a bad speaker. Can you take the circuit board and any protecting plastic off the left speaker cup?
Score 1
3 Comments:
I should be able to do that. What should I look out for?
by Share
@mrvolcan Make sure there are 2 wires connected from the speaker to the board. Make sure both of the wires have continuity from one side to the other. If both of those pass, comment both checks passed.
by Share
I have the exact same problem. This evening the left speaker if my sony wh-1000xm2 decided to stop working. I don't know what to do.
by Share
Add a comment
I assume it is an connection problem between the pcbs on both sides. I have the same problem now with my headphones. I seems like there is no signal for the left driver. Anybody figured out the problem?
Add a comment
Add your answer
Moritz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 51
All Time: 2,082
