Up to 20% off select tools
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Broken Sim Reader Pins
Hello,
I always wanted a first generation iPhone and I bought a first generation IPhone to repair. I realized that my device is not reading SIM cards. Then I opened it and saw the broken pins. Can I just buy a broken motherboard and replace the sim slot? If not how could I fix it?
Score 1
Add a comment
1 Answer
Chosen Solution
I have replaced sim holders on a lot of iPhones but not this model. It looks easy enough. I am not sure how much heat you will need to melt the solder on these models, if you flow the joints with low melt solder you shouldn’t have a problem although you will probably need a hot air station as well as an iron.
The hardest part will be finding a non-working one to buy.
Score 2
1 Comment:
Thank you so much?
by Share
Add a comment
Add your answer
Batu Köseoğlu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 409
