Missing Pads Charge Port
Hello,
I am missing charge port pads for pins 5, 12, 14, and 20 for an iPad 6th Generation WIFI. Can some help me identify any test points on board where I can jump these to the connector?
Thanks in advance!
5 Comments
you need to mark the pads in the photo or picture - the numbers of pins and lines are not marked on any of the available diagrams (let's at least set the starting point and the direction of counting - so as not to make a stupid mistake). At the same time, I confirm - such a check is possible
by bert.harmidomski Share
I am missing the ones highlighted in light blue.
by mmejia04 Share
wait...
mmejia04 post a picture of your actual board as well. That way we can actually see the placement of the components and follow the traces as per schematic....
by oldturkey03 Share
I posted a new picture, the pads inside the red boxes are the ones needed. The other pads are either connected to ground or have a second connection to the same point.
by mmejia04 Share
