The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
Radiator Fans Run Continuously
2014 VW Passat SE, 1.8L Turbo Gas Engine. Recently changed radiator and turbo cooler, along with A/C condenser. Then changed radiator fans (both - entire assembly). Now fans won’t shut off. Have been told may be ambient sensor, but cannot locate. Cannot locate control module, etc. No codes in ECM. Help please!
Add a comment
1 Answer
Chosen Solution
I had my cooling fans running at max on my vehicle (and always showed cold engine), and it turned out to be the engine temp sensor went bad.
On eAutoRepair.net you can subscribe to access the full repair/service manual for your vehicle. It should help to locate the components in the vehicle.
1 Comment:
Thank you!! I’ll definitely check out that website!
by
Add a comment
Add your answer
Robert Mayo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 45
All Time: 2,012
