The DuraForce PRO is a Verizon rugged smartphone released in October 2016, that is built to be water/dustproof and screen shatterproof. This phone also has a removable battery (note that removal of battery will void the warranty) and many other parts. Model numbers: E6810.
Phone will not turn on
My phone froze and then shut down at about 8% battery. It will charge, but I can’t get my phone to turn back on even after 30 minutes of charging. I’ve tried holding the power button and the power button with either of the volume buttons. Nothing I try seems to work.
Score 1
2 Comments:
What kind of phone do you have? I’ll see if I can be of assistance.
by
Kyocera Duraforce Pro 2
by
Add a comment
1 Answer
@silverwolfcc I suggest you replace the battery. It may look like it is charging but may no longer hold a charge. Replace the battery and re-evaluate. If nothing else it will give you a known-well starting point for further troubleshooting.
Add a comment
Add your answer
Kendall Morse will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,134
