Up to 20% off select tools
Machine does not supply water
Why does water not come into machine
Add a comment
1 Answer
Most Helpful Answer
Hi,
Have you checked that both of the water supply taps (faucets) for the washer are turned on?
Does it do this when either hot or cold is selected?
If hot works OK but not cold (or vise versa) then there may be a problem with the water inlet valve in the machine or perhaps the control board.
Score 1
Add a comment
Add your answer
Amechi Idigbe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 614
