1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
MacBook Air not turning on
I have a mid 2012 macbook air, i used to get service battery message on and off, like a moron i kept delaying to buy a new battery. last night i left the laptop on charge from morning its not turning on, no sound from the fans as well.
I have tires SMC reset, Ram reset, power cycle, holding the power button and plugging in the charger, nothing helped
I opened the bottom and noticed the battery is bulged, i disconnected the battery and tried turning on but nothing. when magsafe is connected its green with the battery connected and amber when the battery is disconnected.
during the SMC reset light blinks from green to amber when the battery is disconnected. With the battery connected SMC reset does nothing.
does that mean laptop is dead, would replacing the battery help?
thanks
Add a comment
1 Answer
You really don’t have a choice here, you need a new battery to get your system going MacBook Air 11" (Mid 2011-Early 2015) Battery And here’s the guide MacBook Air 11" Mid 2012 Battery Replacement
Replace a 5100 mAh battery compatible with the MacBook Air 11" Mid 2011 to Early 2015 A1370 and A1465 model laptop. 38.75 Watt Hours (Wh). 7.6 Volts (V). Battery model A1495. Image
Product
$49.99
Add a comment
Add your answer
rabbi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 252
