Up to 20% off select tools
The Samsung Intercept SPH-M910 is a midrange Android smartphone sold by Sprint, marketed as a newer, more affordable version of the popular Samsung Moment. Released in 2010 with Android 2.1 Eclair.
How to replace the flex cable
i took my samsung intercept in to get repaired.they told me it was the flex cable that needed replaced and wanted to charge me 79.00.So now I am researching on how to do this myself.I have already ordered the flex cable.I now just need instructions on how to replace it
Score -1
Add a comment
1 Answer
Most Helpful Answer
scott, check on here for the Incercept SPH-M910 disassembly. Hope this helps to get you started.
Score 1
1 Comment:
Same problem here, and the dis-assembly article does not go that far. Between step 8 and 9, there could be more detail showing how the LCD flex is mounted to the keyboard slider. The flex terminates on a board which is attached to the keyboard slider mechanism. This ebay listing http://www.ebay.com/itm/Flex-Cable-for-S... (or search ebay for m910 flex) shows the board. It is mounted with pins and adhesive and pops out.
by Share
Add a comment
Add your answer
scott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 936
