The Sharper Image M18A is an Android tablet with a 10 inch display and Wi-Fi only. It has a 4GB memory SD card up to 32 GB. Repair for this device is straightforward and requires common, simple tools.
I need power adapter
Where did I get a power adapter for The shaper image M18A .
Add a comment
1 Answer
I will assume it charges via the USB port. A compatible USB cable and a USB power block capable of supplying the current rating of the tablet will work fine. The voltage should be 5V since it is USB, but verify that on the tablet or from tablet specs.
Add a comment
Add your answer
Eric Getter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 264
