Up to 20% off select tools
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Controller buttons not working
When I play certain games such as the sims 4, the left thumb stick constantly moves but in other games is fine . Also whilst playing the sims the d pad doesn't work at all? But in other games is perfectly fine?
2 Comments:
connecting to a computer? or on the xbox console?
by Share
Connecting to my xbox 1
by Share
Add a comment
1 Answer
The fact that it only happens in Sims 4, and the D-pad works in other games, is a big clue — a broken D-pad usually fails everywhere, not in one game. So first check Sims 4 itself: reset its controls to default, turn off any mods or custom control schemes, and check whether the game is using a different controller profile or has camera controls mapped to the stick.
Also, with the controller on a table and untouched, watch whether the left stick creeps on its own in other games. If it only creeps in Sims 4, that again points to that game's settings.
To check whether the controller itself is sending those inputs,test your controller online for free and press each D-pad direction and move the left stick slowly. If every press registers cleanly there, the hardware is sending the right signals and the fault is almost certainly in Sims 4's settings, mods, or profile. If a direction misses or the stick drifts untouched, clean around the stick, check for a stuck button, and test wired versus Bluetooth before opening it.
Disclosure: I run this free tester.
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 223
