The Lenovo G50-70 can be identified by model information printed on the bottom (model name 20351), or on sticker next to track pad. This laptop has a 15.6 inch screen with Dolby audio. Manufacturing began in 2014.
My PC doesnt start anymore after disassembly
hi to all,
i tried to fix the display of a laptop lenovo g50-70 (it blinked when it was moved), so i disassembled it, and tried cleaning the wires that connected the display to the mobo, now the PC doesn't start, the fan doesnt start, i dont hear the hdd spinning, but the power and charging leds are on. someone can help me on what it could be the problem?
Update (06/05/2021)
i have cleaned the connector with this, before cleaning the display was going on and off, yes the changing light turn on when i plug the power in
2 Comments:
i have resolved by removing the bios battery, now it’s booting! ty anyways
by
@lcxbnr thats good to know that a CMOS battery can cause that type of issue.
by
Add a comment
What did you clean the connector / wires with? When it blinked, did the screen go off and then come back on? I know that RAM issue can cause some strange things to happen such as display and no boot.
Does the charge light come on when you plug in the power adaptor?
Update (06/05/2021)
If your pc has two sticks of ram take them out and boot the laptop up and see if it posts. If so then test each stick of ram by placing one in at a time.
Add a comment
Hello.
I had this problem. I mount and dismount the PC several times. All was according to manual and youtube videos. When I plugged the power adapter the fan moved a little, then stopped, light in the power indicator switched on, but pressing the switch on button didn't work. I read that these computers had issues with the RAM memories. I removed one of the two I have. I tried again, it worked. I switched the position of the two memories, it worked again.
Just in case this is helpful for someone, I wanted to post.
Add a comment
Add your answer
Luca B will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 41
All Time: 677
