Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
Rear running lights do not work?
The rear running lights do not work on my 94 GMC Sierra . My turn signals and hazards are fine. and brake lights work when I hit pedal , but my tail lights that stay lit while driving do not work and I have changed the bulbs already and no fuse is blown. Any suggestions?
Score 1
Add a comment
1 Answer
If fuses and bulbs are fine then check the switch. Make sure that it is supplying the running lights with power when selected. If not, and you've got power coming into the switch, then you need a new one. If it IS sending power to the lights, then you'll need to trace the wires back and make sure they aren't broken. If the power wires aren't broken and you're getting power to the lights, then you'll need to chase down the ground.
2 Comments:
Wait so I have no tail lights or running lights and I have power coming into the switch but not out to the lights. And I just tried replacing the switch what next?
by
@kaidadehaven so you had power TO the switch but not FROM the switch? You replaced the switch and still nothing? Verify power is coming from the new switch first. Then see if there's power at the lights. Could be a broken ground or broken power wire.
by
Add a comment
Add your answer
Von will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 38
All Time: 3,808
