Repair your Dyson DC40 Multi Floor Exclusive vacuum with a replacement guide.
Intermittently quits when pushed forward
Machine quits when pushed forward, starts when pulled back again.
Add a comment
1 Answer
Most Helpful Answer
Sounds like an electrical problem, most likely the power cord is broken inside the insulation, try simply moving the cord back and forth right where it meets the vacuum and see if you experience the same issue, if you do you need to replace or repair the power cord.
Score 1
Add a comment
Add your answer
Scott Rusch will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 21
All Time: 251
