Charge is decreasing on charging
Power problem not chraging
Score 1
1 Comment:
Chances are your charger is either dysfunctional or doesnt provide enough power to the tablet, try isolating whats going on. Try a different charger if it works you know the OG one is either broken or insufficient.
by
Add a comment
1 Answer
This is probably not an issue with the tablet itself, this is probably the charger you’re using. Try using the charger provided by the manufacturer or use a different cable/adapter.
Add a comment
Add your answer
Suvosree Ray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 31
All Time: 872
