Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
Charger Port Burning Excessively
My Samsung S10 charger Port heats up excessively when I plug it in and let's off a burning smell and doesn't provide any power to the phone. After about 10-20 seconds being plugged in the chargers are really hot to the touch. Is there a solution to this?
Score 2
Add a comment
Most Helpful Answer
@helpmelefty, Actually the two sides of a USB-C connector are not identical; they actually use different communication channels depending on which side is up. Here are a couple of images courtesy of allaboutcircuits.com.
Figure 1. The USB Type-C receptacle. Image courtesy of Microchip.
Figure 2. The USB Type-C plug. Image courtesy of Microchip.
You'll note that the TX/RX pins actually have two separate channels that get swapped when the connector is flipped. There are two different channel configuration (CC) pins as well, so it's entirely possible that some circuitry works differently in one orientation vs. the other. For example if one CC pin is bad but the other is functional, you can get high power/fast charging on one side but not the other.
It sounds as though on your phone there's some kind of problem with the fast charging circuitry, but it's impossible to say exactly where the problem originates; whether it's the charging port on the motherboard or perhaps the power management chips. Unfortunately the USB-C port on your phone is mounted directly on the motherboard so replacing it requires specialized equipment and microsoldering expertise; it's generally not something us home DIY-ers ourselves can tackle without a lot of practice.
At this point I'd say your best chance for repair is to take it to a shop; a good one should be able to diagnose the problem and give you an idea of what it would take to fix it.
Score 2
Add a comment
This just started happening to my Samsung. Started in car with fast charger connected. I disabled the fast charging capability of the phone and so far that did the trick for now. I am now getting the "Check your charger connection" message when plugging in to "Make sure the cable and charger are properly connected" indicating something is still off randomly. If I flip the usb-c cable the message wont appear. Its charging in normal mode at the moment without the burning smell that will likely kill the device.
I would like to understand how the charging works and why flipping the usb-c cable makes a difference. I thought both sides are universal but despite the cable and ac power brick I use to test I get the same outcome. One side gives me a warning while the other does not.
Add a comment
Add your answer
Kade O'Regan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 1,257
