Bluetooth on-ear headphones with 40 mm drivers and a 610 mAh battery. Released in 2014.
speaker and battery cable replacement
Hi, my headphones stopped turning on, after searchin i found it's because cable conecting main board with battery and speaker is broken and connected battery positive with speaker. I need help with tear down, i dont know ho to open plastic slider.
1 Comment:
Hi @jonasskuhrovec
I don't see any other options but unscrewing that golden bolt. Have you tried it?
by
Add a comment
1 Answer
You can disassemble the earpieces. These consist of screws and plastic tabs. You already did (most of) that.
I don’t know a way to open the headband in case you need to replace that cable.
You can try to push or pull new wires through.
Add a comment
Add your answer
Jonáš Skuhrovec will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 273
