2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor uses DDR3 RAM Graphics processor is FX9400 with 128-256mb of VRAM depending on installed system RAM.
Apple Install Disk versus Ubuntu EFI
Trying to upgrade the disk in the mini I ran into a problem. It seems that if Ubuntu is installed first, the Apple Install disk isn’t even seen as a bootable disk. Using Alt to invoke the boot manager, only the Ubuntu/EFI partition showed. Just as a band aid I grabbed a new disk and installed it. Then the Apple Install was bootable and the install went smoothly.
How do I get rid of the Boot Manager Ubuntu installed so I can put Apple OS on that disk ? Now if I had a drive enclosure then I’d put it in there and use Disk Utility, but I don’t. Nor do I have a two disk system except an older Mac Pro that might run OS 9.
Add a comment
1 Answer
You will need to reformat the drive fully as I outlined in your other posting: How to reformat an SSD?
Add a comment
Add your answer
James Walker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 16
All Time: 347
