First manufactured by HP in 1979.
stopped working after wrong battery installed
Battery store installed too powerful a battery (somehow same size as N type so fit} in HP 41CV and it never worked again with N Type. Person said it was “fried” and gave a different model replacement.
Is it possible to fix or is it permanently damaged from overload.
Score 1
1 Comment
en el circuito hay algun componente que actue como fusible ante una sobretension?
by
Add a comment
1 Answer
Chosen Solution
Hi,
It may be possible to fix it but looking at the start of the troubleshooting section in the service manual, you will need an ET-11966 service rom module and a port extender to start performing the tests to know what may be the problem.
I can’t find either online, you may have better luck
Score 1
Add a comment
Add your answer
Kevin Kuehn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 27
All Time: 544
