Up to 20% off select tools
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
Speedometer doesnt work or sticks
speedometer doesnt work
Score 2
3 Comments
what engine and what type of tranny do you have?
by Share
I have the same problem with my speedometer not marking when the truck warms up. It marks on cold mornings but then stops after about 20 minuets. I changed out speedometer and speed sensor. And the problem persists. Any help would be greatly appreciated.
by Share
2002 gmc yukon denali AWD speedometer not working Had new stepper motors put in cluster new speed sensor in transfer case new abs wheel speed sensors put in both fronts. no problems with transmission shifting . cruise control works just no speedometer. the info center went out when it quit working when you have 1/4 tank of fuel says you can go 0 miles on fuel, you fill tank up you can go 14.2 miles not sure what is going on with it.
by Share
Add a comment
Chosen Solution
To avoid being accused of trying to alter your odometer, I would have this one repaired at the dealership.
Score 3
1 Comment:
+1 for Mayer. The instrument cluster has "stepper" motors in them. This make and model are notorious for them failing. The dealership will perform a "sweep" test where they will use the computer and command the needles to sweep. If it fails the test, which it likely will, they will need to replace the cluster. Unfortunately the dealer doesn't offer parts for this. They will however take the old one and give you a remanufactured cluster. Expect to spend $350-$450 for the cluster and $100-$300 for labor.
by Share
Add a comment
I know it's an old thread. But this is a great link. It depends how involved you want to get on this project but for someone who isn't afraid of taring into things here you go
How to replace your stepper motors in the instrument cluster for some GM vehicles:
http://forums.trailvoy.com/showthread.ph...
Score 2
Add a comment
It's the stepper motor behind the instrument cluster, GM had a lot of problems with that. If you know how to solder , you can get a new updated motor for about 12.00 and solder it on. It's pretty easy .
Score 2
Add a comment
It is probably your Vehicle speed sensor. It is mounted on the tailshaft of the transmission and is held it with one small 8 mm bolt. Your speedometer wont work right and it will probably shift wrong or wont shift at all because the transmission relies on the speed signal to know when to shift. The tahoe/yukon use the 4l60e transmission.
Add a comment
I took my battery out to fix a hardline hose on my wiper squirter pump motor that cracked.
After putting the battery back in my speedometer was pegged out past 100mph!
Looked online at how to fix ……Ha Ha! Not pulling dash apart….
and thought all I did was take the cable off!
well I just had someone watch the gauge while I wiggled the
NEGATIVE battery cable (Alarm was going off and on) until it went back to 0mph!
I would try this FIRST! …… It CAN be that easy!
1 Comment:
Thanks,worked for me also,,my speedometer went to 100 after changing battery
This fixed the problem
by Share
Add a comment
if the speed needle doesn't work is the milage frozen or is it counted?
Add a comment
Add your answer
t gabler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 46,895
