Launched on November 2014, the HP Stream 13 is a thin unibody Windows® laptop priced to compete with Chromebooks and the entry level MacBook Air.
Where can I buy replacement screen
who sells replacement parts?
2 Comments
Hi @cyberrescuers ,
What is the full model number of the laptop?
by
@jayeff I have a stream 13
by
Add a comment
1 Answer
Chosen Solution
Hi @cyberrescuers,
Here’s the maintenance and service guide for the laptop.
Go to p.13 Item #4 or p.14 Item #1 to find the part numbers for the LCD panel for the non touchscreen and the touchscreen model variants for the PC.
If you search online using only the part number appropriate to your particular model variant you will get results for suppliers.
The manual also details the necessary pre-requisite steps and then the procedure to remove / replace the panel.
Hopefully this is of some help
Score 1
1 Comment:
The issue with these Stream devices is cost :-(. Parts cost as much as a used one, or about as much as a new one on some of these.
by
Add a comment
Add your answer
klarenceray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 292
